Ciscoworks Problem with Netconfig
williamka
Level 3
Level 3
While initiating a a job using RME Netconfig, in job schedule and option, the copy running config to startup is not functional.
The job will complete successfully but the running config is not copied to startup. We are using LMS bundle 2.5
Is anyone else experiencing the same issue with Ciscoworks RME Netconfig
swsservice
Community Member
Did you try adding "wr" in Adhoc instead?
Updating the script with end and wr mem is successful. The automatic function to wr start to run is not.
