Clarification on inside interface for ASA5506-X
ndjake
I was hired to do some side hustle work recently which included setting up an ASA5506-X with Firepower Module.  Let me preface this by saying that I haven't touched an ASA for 6-7 years so I'm a bit rusty.  The initial setup went just fine and I was able to get it set up with a default route to give the two connected hosts internet access.
I ran into some issue though when attempting to use the "inside" interface in commands.  For example, I wanted to give SSH access to any host on the inside network (ssh 192.168.10.0 255.255.255.0 inside) I would get an error back stating it was an ambiguous statement.
Similarly, I ran into an issue trying to configure a nat to an inside host using the following command:
nat (inside,outside) static xxx.xxx.xxx.xxx
I eventually ended up resolving it by specifying which inside port interface on which the host was connected:
nat (inside_4,outside) static xxx.xxx.xxx.xxx
Did I miss a step in the inital setup to make the ASA recognize the "inside" object or is it the result of the NGFW operating differently?
Jake
Your observed behavior is the result of the new default-config with bridged inside interfaces:
https://www.cisco.com/c/en/us/td/docs/security/asa/asa98/configuration/general/asa-98-general-config/intro-start.html#concept_BE56002F4C3C4B478BDCC44A530076E0
Each "swichport" that belongs to the inside BVI has an individual nameif and is referenced individually.
Philip D'Ath
I suspect your SSH issue might be because you have multiple interfaces starting with the name inside. A software upgrade might fix that.
