Configure authentication LDAP using sAMAccountName and userPrincipalName at the same time
daviddeleye
I would like to configure authentication for our anyconnect connection using ldap to check the credentials against our AD. I can configure to use either sAMAccountName or userPrincipalName but not both at the same time.
ldap-naming-attribute sAMAccountName
ldap-naming-attribute userPrincipalName
gives following output
aa-server TEST (inside) host 1.1.1.1
So in short, is it possible to check both?
You can't specify both under single aaa-server group. But try to use
sAMAccountName and enable strip-group and strip-real option. This should
make both DNS and Group logins working.
Hi Mohamed,
Thank you for the swift response.
It is unclear what DNS and group login are.
Could you explain what you mean by this?
Thank you in advance!
