Confirm traffic flow between firewalls
mahesh18
Level 6
Level 6
Hi Everyone,
Here is a setup
Server------ASA1----Switch1-----Switch2-----inside interface-ASA2----outside public IP
where server1 ASA1 and Switch1 is new setup.
Traffic from server needs to go to interent.
Server subnet is 10.50.50.x
ASA inside interface IP is 192.x.x.x.
I need to confirm that ASA2 will allow the server traffic to internet and backforth.
I ran the packet tracer on ASA2 and it worked fine.
IS there anything else i can check to confirm the traffic flow from ASA2?
Currently server is not connected so that i can not test in real time?
MAhesh
Shivapramod M
Hi Mahesh,
Packet tracer will show the packet flow on the ASA inclusing what NAT, route and ACL it will take.
Since there is no live traffic so we can not take the packet capture on the ASA. Ideally if the packet tracer shows no issue then the configuration on the ASA looks good. If you need to confirm the packet tracer output then you can share the output of the packet tracer.
Shivapramod M
Please remember to select a correct answer and rate helpful posts
Shivapramod M
Hi Mahesh,
Shivapramod M
Many thanks.
MAhesh
