How to NOT bottleneck the inside interface of ASA when using Hierarchical Queuing for QOS
Dean Romanelli
Level 4
Level 4
Hi All,
I have the following on my ASA for VOIP QOS priority over a T-1 speed WAN:
class-map QOS-IN
match access-list qos_priority_in
class-map QOS_OUT
 match access-list qos_priority_out
policy-map QOS-POLICY
 class QOS-IN
  priority
 class QOS-OUT
  priority
policy-map RATE-LIMIT:QOS-TRIGGER
class class-default
shape average 1536000
service-policy QOS-POLICY
service-policy RATE-LIMIT:QOS-TRIGGER interface outside
Question 1: In basic priority queuing, you specify "priority-queue outside." In the above type (Hierarchical), you do not. How can I ensure this policy will NOT also shape my inside interface to 1.5Mbps and will ONLY limit my outside port if I don't tell the ASA where the priority queue is in this method? I am assuming it is controlled by which interface you apply it to as in the last command above?
Question 2: The examples I've read only configure priority under the policy map for the outbound class map. However, I want the return traffic from my VOIP provider to also be prioritized to enter my LAN first. Due to that, I also set priority on the "QOS-IN" class under the policy map.  Is that OK? Just want to ensure that including QOS-IN with priority under the policy-map that is being called by my shaping policy-map will not again cause my inside interface to bottleneck down to 1.5Mbps.  Pretty sure it won't, since that flow is for outside-traffic-in and the policy is applied to the outside, but just want to be sure.
Akshay Rastogi
Hi Dean,
The last command mentioned 'service-policy' would take care of your policy and would apply only to Outside interface. It would not bottleneck you inside interface to 1.5mbps. This Answer your 1st Question.
When you apply a policy on an interface, it takes care of the traffic in 'in' and 'out' direction of that Interface. So this Answers you 2nd Question.
Hope it helps.
Akshay Rastogi
Remember to rate helpful posts.
Akshay Rastogi
Hi Dean,
Hope it helps.
Akshay Rastogi
Thank you Akshay.
So if the policy takes care of in and out, then I don't need to configure the QOS-IN class-map or call it in the policy-map or configure the ACL for the outside-in flow if the QOS-OUT class map, inside-out ACL & policy map applied to the outside will also prioritize the return traffic automatically right?
Hi Dean,
Yes, you are right. This outside policy will be applied to outbound and inbound traffic. You do not need to specifically configure QOS-IN. If the traffic matches in that oe access-list then that is enough to process.
Akshay Rastogi
Excellent. Thank you very much.
