Creating Remote Storage Device in Firepower Management 6.1
Silver_Cat
Hello Guys, I am getting the following error message while trying to create 'Remote Storage Device' type NFS in FMC version 6.1 .
My NFS is running on windows 2012 server and during testing i do see a file name "sf-remote-storage_test.txt" created in the folder.
Any ideas ?
TCSPB
I ran into this issue setting up backups using NFS.  Turns out I had to change Security permissions on the main folder to allow everyone modify access and then it worked.
ziqex
Level 4
Level 4
Did you get your issue resolved?
If yes, would you mind sharing the resolution?
