Debug messages in CLI (Do not have FDM)
johnchrapkowski
I have a firepower 1140 and I wish to see debug messages in the CLI.  I ssh in, enable system wide logging, then run debug tcp.  after I go into the support console with support diagnostic-cli.  Exactly one time I have seen debug messages but not since.  I don't even know where to start to troubleshoot this (I have disabled logging and tried everything from scratch but still nothing).
14 Replies 14
If I am right there is two debug what you do here is see the debug of fxos.
But I will make double check about this point
system support diagnostic-cli is the right command, it's not a FXOS command.
What debug information did you configure, console/buffer? Provide a screenshot of the configuration
Also from system support diagnostic-cli run show logging to confirm what logging is enabled.
What FTD version?
I do not have FDM unfortunately so I am only using CLI.  Do you know of a guide to set up logging properly through the CLI?
Running show logging indicates console logging is disabled and is buffer logging
My version is 7.0.1
@johnchrapkowski what are you using to manage the FTD? You can either manage the FTD locally using (FDM) or centrally using FMC/CDO/cdFMC. I assume you have an FMC?
You cannot manage an FTD from the CLI, it's 99.9% via the GUI.
Apologies as I am new to cisco equipment and getting used to the terms of their stuff.  I use the web interface for configuration stuff, is that what is called FTD?
@johnchrapkowski You can only manage the FTD using a web interface, either locally using the Firepower Device Manager (local management) or FMC/ CDO (central). Do you connect to the FTD itself to manage it? if so then you are using FDM to manage the device. If you use another device to manage multiple FTD's then that probably FMC or if hosted in the cloud then it's CDO.
The configuration of the logging settings are completely different depending on how you manage the device.
If you use FMC, follow this guide to configure logging - https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/200479-Configure-Logging-on-FTD-via-FMC.html
If using FDM here is how you enable logging via the GUI.
In both scenarios you must save and deploy the changes.
Thank you!  I am understanding much more now
Hello Rob,
I have exact same settings on my FDM as you have shared, yet I am unable to see any debug messages when trying debug webvpn anyconnect 255
Did you do these steps
Debug
System support diagnostic-cli
Show console-output
I tried:
debug tcp
show console-output returns error and running show? gives me:
firepower> show ?
checksum Display configuration information cryptochecksum
community-list List community-list
curpriv Display current privilege level
disk0: Display information about disk0: file system
flash: Display information about flash: file system
history Display the session command history
import Show imported objects
inventory Show all inventory information for all slots
policy-list List IP Policy list
prefix-list List IP prefix lists
version Display system software version
Debug
Stop capture with ctrl+a then d
Show console-output
You need to change to enable mode before using "show console-output".
However the right way it to enable console logging from the respective manager (FDM or FMC).
Sure as my  instructor @Marvin Rhoads @Rob Ingram  mention using fdm or fmc is better
johnchrapkowski
I cannot push it until later as we have some production data running on this right now, but I genuinely thank you all so much for this!  I will report back later what results
