Design Guide for FTD and FMC
ajeet5857311
Is there any design guide for FTD and FMC. I have partner portal access, please suggest if anyone have idea if its there. As we are migrating from checkpoint to Firepower so trying to understand:
Thanks.
S M85
Level 4
Level 4
There are a lot of CVD guides. So it depends on what are you looking for? Can you describe a specific scneario? Check Point perimiter swap for FTD? What features are you enabling for example.
You can also take a look into the different Cisco live presentations regarding FTD. I can recommend BRKSEC-3455.pdf.
Cisco Live sessions, videos and exhibitors from all global conferences
