DHCP problem Wlan 2125 and ASA 5505
Hello
I have a problem with giving out dhcp to clients in a new wlan setup.
Router/Firewall ASA 5505
Cisco WLC 2125
Switch Catalyst 2960
16 Ap's  AIR-LAP1131AG-E-K9
Everything is up and seems fine, but when connecting with clients they does'nt get ip. If I set statci ip its working fine.
I have one subnet 192.168.17.0 thats used for everything on wireles called dmz.
See my setup in the image
First i try to set the ASA 5505 as a dhcp server and have the manager and the ap-manager interfaces on the wlc set to 192.167.17.1 as dhcp. Then the AP's get ip, but not clients. Now i try to use wlc as dhcp, but when I set the dhcp server on the management interface 192.168.17.5 (itself), which the wlan use, I loose contact with the wlc for some reason. (But when I did this I managed to have it to give out one ip, before it failed)
Then I tried to make another dynamic interface on port 1, with a unice ip and set 192.168.17.5 (management int) as dhcp server, but then I get a message says I cant use this port and that the ip conflicts with another interface which it does not as I can see (Tried several ip adresses)
Maby its not ideal at all to use the wlc dhcp server with 16 AP's so the best would be if I could use the ASA 5505. Anyone knows if this is possible or what I'm doing wrong with the wlc dhcp setup.
regards
Trond
Hi Trond,
16 APs should still be working fine.
10 APs is a general guideline to stay on the safe side, but even with 16 APs this should technically work.
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Now I got it working by setting the management interface on the wlc to itself 192.168.17.5, both AP's and clients get ip.
But I read in some cisco documentation that was recomended to use the wlc dhcp server if around 10 ap's som wondered if its then possible with 16+ ap's without trouble.
Trond
Hi Trond,
Fede
