Error in uploading Sourcefire_Snort_Engine_Upgrade-1650-vrt.sh file to the Cisco firepower management center 6.2
MKH
Hello
Whenever I try to upload a Sourcefire_Snort_Engine_Upgrade-1650-vrt.sh on Cisco firepower management center 6.2 , it fails and an upload error occurs.
I could upload Sourcefire_Rule_Update-2017-05-09-001-vrt.sh, Sourcefire_Geodb_Update-2017-05-01-002.sh and
Sourcefire_3D_Defense_Center_S3_Patch-6.2.0.1-59.sh Successfully.
I checked the MD5, It is true.
What is the problem?
Thank you.
Veronika Klauzova
SEU (Snort/Sourcefire Engine Update) file is for 4.X software versions. If you are using 5.X and higher (6.0.X, 6.1.X, 6.2.X) then you should use Sourcefire Rule Update (which includes Snort engine update).
Best regards,
Veronika
Veronika Klauzova
Best regards,
Veronika
