Existing PIX devices not using VAC+ card
philliplyle
Our existing restricted license PIX devices do not seem to be utilizing the VAC+ cards that we recently installed in 3 PIX 515s. From what I've read, it should just work. Here is output from two of the devices:
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
ILPIX515 up 98 days 3 hours
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : Crypto5823 (revision 0x1)
0: ethernet0: address is 0015.438a.edaf, irq 10
1: ethernet1: address is 0016.438a.edb0, irq 11
2: ethernet2: address is 000e.0c71.233b, irq 5
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Cisco PIX Firewall Version 6.3(1)
Compiled on Wed 19-Mar-03 11:49 by morlee
eLibPIX up 123 days 3 hours
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0051.54ff.335c, irq 10
1: ethernet1: address is 0051.54ff.335d, irq 7
2: ethernet2: address is 0092.2743.2fd6, irq 11
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
Maximum Interfaces: 6
Guards: Enabled
This PIX has an Unrestricted (UR) license.
Any ideas? Thanks for all of your help,
Phil
gfullage
What makes you think they're not being used? The "sho ver" output above includes this line:
which indicates the PIX can see the VAC+ card, and therefore will be using it.
By the way, you can apply for a 3DES license for your PIX's now, they're free.
https://www.cisco.com//cgi-bin/Software/FormManager/formgenerator.pl?pid=221&fid=1283
Thanks for the link, was gonna go searching for that tomorrow.
I don't think its being used because on a newly purchased 515E unrestricted it shows (VAC+) in parenthesis; and all examples of what to look for say that it should show VAC+ specifically, not just Crypto5823.
Are you saying that Crypto5823 by itself means VAC+?
Thanks for your help.
-Phil
Yep, definately. My box in the lab shows the following:
sv2-11(config)# sho ver
Cisco PIX Firewall Version 6.3(4)
Compiled on Fri 02-Jul-04 00:07 by morlee
sv2-11 up 5 days 1 hour
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
0: ethernet0: address is 0050.54fe.ea5e, irq 11
1: ethernet1: address is 0050.54fe.ea5f, irq 10
2: ethernet2: address is 00e0.b605.6cf7, irq 9
3: ethernet3: address is 00e0.b605.6cf6, irq 9
4: ethernet4: address is 00e0.b605.6cf5, irq 9
5: ethernet5: address is 00e0.b605.6cf4, irq 9
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Enabled
Maximum Physical Interfaces: 6
Maximum Interfaces: 10
Guards: Enabled
Serial Number: xxxxxxxx (0xyyyyyyy)
Running Activation Key: 0xaaaaaaa 0x445340f4 0x9e65fbfe 0xb6c5fc9e
Configuration last modified by enable_15 at 14:06:24.349 UTC Fri Mar 4 2005
sv2-11(config)#
FYI, a VAC (not a VAC+) will show up as:
Encryption hardware device : IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.5
Yer awesome =)
