failover times for lan basd failover
carl_townshend
Hi all, for my asa 5520 on the default active/standby config, what is the time it would take to failover to my other device. ?
Hi Carl,
The failover times will depend on the type of failure that occurs. Here is a list of the minimum, default, and maximum failover times for the ASA under various conditions:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/failover.html#wp1149492
Hope that helps.
-Mike
