Dynamic IPsec Between a Static ASA Hub and Dynamic ASA Spoke
LOUIS BOUCHARD
anyone can give me an hint on the sample configuration for both hob and spoke.
I have found what I need between and ASA hub and IOS spoke
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807ea936.shtml
but I also need between two ASAs
acomiskey
Level 10
Level 10
The easiest way I found to accomplish this is to use the DefaultL2LGroup on the hub ASA. On the spoke ASA you will use a tunnel group equal to the ip of the hub ASA. Post your configs if you need a hand.
Hub ASA
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
Spoke ASA
tunnel-group ipsec-attributes
pre-shared-key *
Configure the rest the same way you would any other L2L tunnel.
