FDM running-config not showing
dpditstaff
I recently restored a 1040 from a previous backup.  I can show the running config at the CLI but the GUI (FDM) does not reflect the configuration.
@dpditstaff what configuration is incorrect? re-deploy the policy after the restore?
from Cisco Doc.
You cannot perform other actions in the FDM or the CLI while the system is rebooting or shutting down.
During reboot, the FDM page should refresh when the reboot is complete and bring you to the login page. If you try refreshing the page before the reboot is complete, the web browser might return 503 or 404 errors, based on the operational state of the FDM web server at that point in time.
For shutdown, the system will eventually not be able to respond at all and you will get 404 errors. This is the expected result, because you are completely turning off the system.
MHM
