Fire Power 7010. RPC timed out.
n.avramenko87
Hello! Help me please! I have a problem. When  I try to apply new policy for my device in FireSight I see an error "-RPC timed out". How can I solve my problem? May be it is need to increase a time out?
Actually it needs to be created in there.
Create the file /etc/sf/rpc_timeout.conf on the DC and include the following lines:
sudo touch /etc/sf/rpc_timeout.conf
rpc_timeout 128;
command_timeout 785;
wait_timeout 842;
Rate if helps.
Yogesh
8 Replies 8
yogdhanu
Please check if there is enough bandwidth available between the firesight and sensor.
You can try to use SCP protocol to transfer a file and check if there is no enough bandwidth available.
Or check the logs on the DC.
admin@3DSystem:~$ grep 'Error copying file remotely' /var/log/action_queue.log
You can increase the RPC timeout  under /etc/sf/rpc_timeout.conf.
Increase the rpc_timeout by 20 or 30 , command timeout by 3 times and wait time by 300 and test.
You would need to be in root privilege to do that.
Rate if helps.
Yogesh
Thank you! I think there is no problem with bandwidth. And a can not find /etc/sf/rpc_timeout.conf.
rpc_timeout 128;
wait_timeout 842;
Rate if helps.
Yogesh
Thanks! This error is go away. But I have another error "Access Control Policy apply failed".
Could this be because the Device is not in use on the network? The ports hardware is not yet connected our network.
When a try to apply settings to device - i have error - "Unable to connect to DB". How i can solve this problem? Thank you!
Ok! I will try in the evening. May be error with base will go away too! Thanks!!!
I tried to connect the network to the device.Ports are not linkd. When i try to apply access policy to firepower - i have error - "access policy faild" Where is my mistakes?
Yes the network connectivity is must for the policy apply to work.
Rate if helps.
Yogesh
