FIREPOWER 2110 TRAFFIC NOT GOING THROUGH THE WAN INTERFACE
kayodeodeyinka7
Hi Professionals,
I set up a Cisco 2110 device with a FTD 7.2.5 ios version but it does not have the following basic interface configuration:
cts manual
propagate sgt preserve-untag
policy static sgt disabled trusted
Please can the absence on this on the interface drop traffic on a WAN port.
Most services on the WAN port are currently not accessible from the WAN.
I have checked the running config and everything looks fine.
Kindly advice on what to do
It should  not effect traffic pass unless you use SGT in network.
Can you more elaborate' is traffic not pass at all?
MHM
balaji.bandi
is this first time setup ?
are you managing FTD with FMC or FDM ?
we do not have any visibility what WAN switch config what Device mode and IOS to confirm what is not working here ?
again this statement is not clear ? before you deploy FTD - they can accessble ? what IP range  ? how does your network diagram looks like for us to assits or suggest anything here.
cts manual
Does your rest of the environment use CTS ?
1. Provide environment information
2. provide high level diagrams
3. post WAN switch information and config where the FTD connected ?
4. when you mentioned basic config - what config you configured ? - by default FW deny all the traffic until you have any ACP rules to allow and routing in place ?
what have you checked ? are you able to ping WAN IP ? from WAN to FTD are you able to ping ?
from FTD it self you able to reach out ?
BB
