01-28-2021 08:54 AM
Dear Community,
I am attempting to create a couple of port channels on my 4140 appliances. I tried to do this through the FMC but it appears I may need to do it via the Chassis Manager? I am trying to create the port channels via the Chassis Manager, it gives me the option to create the port channel but I am unable to add any interfaces to the port channel. The section where to select the interfaces to put into the port channel simply does not provide any options, its blank. I have attached a screen shot. Any ideas?
Thank you.
Solved! Go to Solution.
01-29-2021 10:35 AM
Yes that's normal. It's a bit counter-intuitive but it's an artifact of how the Firepower Chassis Manager does things on 4100 and 9300 series.
01-28-2021 09:01 AM
Dear Community,
I answered my own question. I had already assigned the physical interfaces to the logical device. I went ahead and unassigned the interfaces from the logical device and the Chassis Manager then presented the interfaces as an option.
Thank you.
01-28-2021 09:33 AM
Correct.
For future seekers, here is the relevant section of the configuration guide:
01-29-2021 09:21 AM
Thank you Marvin. I did have one quick questions about the port channeling. I went ahead and disassociated the individual interfaces from the Logical device and then created the port channels (Eth1/1 and Eth1/2 -> PO15, Eth1/3 and Eth1/4 -> PO20). I then associated the PC's to the logical device. When I look at the CLI and the "show interface" command, I do see the PC's are assigned but the individual interfaces show saying "(not associated with Supervisor)". Is this normal? I attached a screenshot for reference.
Thank you.
01-29-2021 10:35 AM
01-29-2021 10:44 AM
Thanks so much Marvin! As always, youre super helpful!
