FireSIGHT low bandwidth high latency to remote sensor.
Rellish83
All,
I'm having an issue pushing an Access and Intrusion Policy to a remote sensor over a Satellite link with high latency and low bandwidth.  Latency is about ~700ms and bandwidth is about 116k, I know state of the art right.  It is experiencing RPC timeouts when pushing the policy updates.  I know the DC is trying to push this policy as ng_apply_pack.tgz which is about 19mb.  I can run this command on the DC “time sfmgr –c “PUTFILE /var/tmp/testfile500k /var/tmp/testfile500k” –u (UUID of sensor)” and will be successful, if i try and make it any bigger it fails.  When adding the -t option for the RPC even at 2000sec it will still fail at a 1mb file.  Any ideas or suggestions would be greatly appreciated it.  Running DC 5.4.1.7 and Senor 5.4.0.8.
5 Replies 5
Dennis Perto
Level 5
Level 5
If you have tried to edit the RPC settings on the Management Center and it did not work, then I would recommend that you upgrade to Firepower 6.X.
Instead of pushing the config form the MC, the sensor will pull.
If you want to play with RPC timeouts, you can try this.
If it fails, you are on your own.
Step 1: Create the file /etc/sf/rpc_timeout.conf on the DC:
admin@DC:~$ sudo touch /etc/sf/rpc_timeout.conf
Step 2: Edit the file to include the following lines with the default values:
rpc_timeout 120;
command_timeout 240;
wait_timeout 600;
Step 4: Increase or decrease the timeout values as needed. For example:
rpc_timeout 128;
command_timeout 785;
wait_timeout 842;
Changing these values overrides the default timeouts.
rpc_timeout = Overrides the default of 120 seconds for RPC (Remote Procedure Calls)
command_timeout = Overrides the default of 240 seconds for file copy operations
wait_timeout = Overrides the default of 600 seconds for distributed calls and Policy applies from a Master Defense Center.
Thanks for the response.  I have tried to adjust those RPC timeouts and I am still unsuccessful in transferring the policies.  I will not be able to upgrade to 6.X until I upgrade the memory on the Defense Centers.
If you have a FS/DC750, DC1500 or DC3500 you can order a free memory upgrade here:
http://www.cisco.com/c/en/us/support/docs/field-notices/640/fn64077.html
Wow thank you for the help I did not know this was a free option.  Really appreciate the support I will see if this can fix the issue.
