FireSigth Center GUI problem
Hi Guys,
I'm  having trouble to access the Firesight Defense Center via GUI page. My question is how can I restart that service with our restarting the whole server.what i see on my page is
Unable to connect
I'm using firefox 43.0.2, it was working before....
any suggestions...
Aastha Bhardwaj
You can restart the services by the CLI the command is : pmtool restartbyid httpsd
If this is 6.0 Defense center then you might also need to restart GUI service by command : pmtool restartbytype gui.
Also you can check if you are getting any errors while accessing GUI in : cd  /var/log/httpd and then
ls the files you will find recent https access files.
Aastha Bhardwaj
Rate if that helps!!!
5 Replies 5
Aastha Bhardwaj
Aastha Bhardwaj
Hi Aastha,
thanks for the commands, I tried it but no workyyyy!.... 😞
Maybe I need to open a TAC case?
Also I restart using this commad.
root@VMFIRE01:~# /etc/rc.d/init.d/console restart
Stopping Sourcefire Virtual Defense Center 64bit...
...ok
Any particular error that you are getting while accessing it ? Did you changed anything wrt to the certificates ?
If you try to get the error messages from the path given earlier.
Aastha Bhardwaj
nothing Sir,
Just the page wont display anything
no certs has been changed....no changes....
rebooting the VM fix the issue...
