Firmware upgrade between 2 Cisco ASA failover mode
mthomaz
I have got two Cisco ASA 5510, where:
FW1 = Primary ASA
FW2 = Failover ASA
I am planning on upgrading the Firmware, for those ASA, but want to get minimal downtime possible.
Can I redirect all traffic to FW2 while FW1 gets upgraded, then back to FW1 while FW2 gets updated?
Or can I just upgrade FW1 and the failover mode will automatically know that FW1 is under maintenance and will redirect all the traffic to the FW2 by itself? Cheers!
Ajay Saini
Level 7
Level 7
The traffic shifting between the firewalls can be done manually or automatically once a fw senses that other has failed. You can do a zero downtime upgrade, please follow the below doc:
https://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/admin_swconfig.html#wp1053398
Just stick to the upgrade path, details of which are in the link.
AJ
Ajay Saini
Level 7
Level 7
AJ
