FMC and AD problem on communication
I have a problem with FMC and Active Directory.
In the realm I have there is an error when I try to download the groups.
And in the available groups there is nothing to show as in the below picture
I have tried the bug described here CSCuy43406 , but no change.
The FMC version is 6.4.0.1 and in another FMC (v 6.2.3.14) I have the config is the same and it works.
Any thoughts?
Thanks and regards,
Konstantinos
When you defined the AD Realm, did you run "Test AD Join" to confirm successful connectivity? If that was succesful check your "Group DN" under the realm configuration.
Can you provide a screenshot of your AD realm configuration please.
See this example of configuring AD Realm on an FMC.
Hello RJI,
I did not set up the AD integration, but the connection was working ok.
In the current config, I have only a "directory username" and password, while the "AD Join username" and password are blank.
The "Group DN" is fine because it is the same in the other FMC where it works.
Konstantinos
