FMC v7.0 ACP rule view settings selection issue
00u17
Earlier FMC 6.6.4 allowed to enable or disable multiple columns in one go to customize the ACP rule window view but FMC 7.0 will not allow you to have that privilege, once you uncheck any of the given options the menu will just disappear but it wasn't the case in FMC v6.6.4. Is there a way to fix this?
Marvin Rhoads
Unfortunately it appears they have changed that behavior, at least for 7.0, 7.0.1 and even 7.1. I just confirmed it on a couple of the FMC servers I have access to.
