Forward 3 inside IP using the same port to one outside IP ASA 5505
slindsey1380
Ok, so I have 3 cameras 172.20.101.15-17 all listen on port 7000. I want to forward them to a single outside IP, but when the user connects I need them to come in on ports 7001, 7002, 7003.
I have forwarded ports before, but never in this fashion, and I have no clue how to do so.
Julio Carvajal
Hello Shaun,
Let's say you are running a version higher than 8.3 and that the public IP is 8.8.8.8
object network Outside_IP
host 8.8.8.8
exit
object network Internal_server_1
host 172.20.101.15
nat (inside,outside) static 8.8.8 service tcp 7000 7001
exit
object network Internal_Server_2
host 172.20.101.16
nat (inside,outside) static 8.8.8 service tcp   7000 7002
exit
object network Internal_Server_3
host 172.20.101.17
nat (inside,outside) static 8.8.8 service tcp  7000 7003
Of course create the ACL's as needed,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
