FTD in Transparent Mode Management On Box
Caue Garcia
Dear All,
I need to configure a FTP 5516-X in transparent mode.
But after convert to transparent and enable de local management (on box).
The output showed the message:
Local manager does not support transparent firewall mode.
The sollution is use FMC only?
Any update?
balaji.bandi
yes you are correct
BB
balaji.bandi
yes you are correct
BB
