FTD Multi-Instance Container Inter-Chassis Cluster 4115 and FMC1600
dbotelhosybistech
Frequent Visitor
Frequent Visitor
1). I am migrating ASA with 7 contexts to FTD.  Attached is the 4115 Chassis Manager Interface screen.  I would like multiple instances to share the same port channel with different VLANS.  Once I associate an Instance with a portchannel, that interface is no longer available for assignment.  The documentation is contradicting and says that with that 4100's not to use subinterfaces in FXOS.  How do I accomplish this?
2) I also attached a screenshot of 2 Instances I created.  the first one FMC1-A is configured as a cluster and I am unable to register it with FMC.
FMC1-B is configured as Standalone and I am able to register it.  I included FTD`-B's screenshot of the interface config screen in FMC.  Where do I assign subinterfaces, FXOS or FMC?
4115 with FXOS 2.11 and FTD 7.01 and FMC 7.01
"Shared interfaces are not supported for bridge group member interfaces (in transparent mode or routed mode), inline sets, passive interfaces, clusters, or failover links."
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/2111/web-guide/b_GUI_FXOS_ConfigGuide_2111/interface_management.html#id_20107
6 Replies 6
Francesco Molino
 once you created your port-channel, you can create sub-interfaces on Chassis Manager and attach each of them to the each instances.
You can see it in that documentation as supported:
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/fxos241/web-guide/b_GUI_FXOS_ConfigGuide_241/interface_management.html
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Marvin Rhoads
If you want an interface to be available for multiple container instances, specify that it is "data-sharing" type when creating it:
FCM - configure data sharing interfaceFCM - configure data sharing interface
Reference:
To change it after it's already been associated you will need to first disassociate it from the logical device and then modify it.
dbotelhosybistech
Frequent Visitor
Frequent Visitor
Port-Channels configured as data-sharing do not appear when configuring an FTD Cluster Instance.  Could you take a screenshot of this configured?
dbotelhosybistech
Frequent Visitor
Frequent Visitor
I'm confused, in this post you say to assign subinterfaces in FMC but above you are saying to configure subinterfaces in Firepower Chassis manager.
https://community.cisco.com/t5/network-security/vlan-sub-interface-unassignable-during-ftd-container-creation/td-p/4534228
dbotelhosybistech
Frequent Visitor
Frequent Visitor
Okay creating the port channel and subinterface on Firepower Chassis manager works only when I create an instance that is STANDALONE.  When I create a CLUSTERED  instance all of those same port-channels and subinterafaces are missing.
