FTD running in ASA Mode
roberto cotto
 does  CIsco firesight running  ni ASA mode sipport  using FQDN in Access-list to  allow or block access by ports ex SSh
18 Replies 18
what issues ? I dont think there is configuration error ,if you want i can share my policy
Well. Assuming that you have the license active, I need to know what is the ASA model you have. Also the version of the FTD.
If the database is correctly setup on the FTD and the model is not 5506 (where the size of the database is much smaller), you also need to configure the FMC to query the cloud for URLs are not in the database.
Also, check the FQDN you are testing with against brightcloud.com and see what's the category.
Actually I dont use FTD ,I am using version 6.2 Firepower and my sensor is 5525
roberto cotto
thanks for the responce
