FTD to remote FMC register problem
i am trying to register my FTD to my remote FMC by this guide with manual method
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp2100/firepower-2100-gsg/ftd-fmc-remote.html#task_imq_yw3_b3b
but when i am adding my FTD to FMC i got error  Registration timed out. Please check connectivity and registration id
I have configured outside static ip address in FTD as managment interface and also registration id and nat id. FMC is behind the nat and I can ping FTD outside ip.
 On FTD i configured manager with command "configure manager add DONTRESOLVE secret123 natid123" as i dont have directly access to FMC. I tried to registrer FTD with IP and NAT ID both, without IP only with NAT ID and also without NAT ID only with static IP but everytime fails. Can you help me?
24 Replies 24
> configure manager add DONTRESOLVE Cisco-123 nat123
use this in FTD and check
MHM
I have configured as you have write but fails, i have added FTD without IP address but with register and nat id
One side must not use IP here fmc behind NAT so did you try above command ? Dis you use same key and NAT-ID in fmc side ?
MHM
Of course using same key and NAT ID yes i tried do as you have written))
then did you use
configure network management-data-interface<<- please read about this command before you apply it
https://www.cisco.com/c/en/us/td/docs/security/firepower/670/configuration/guide/fpmc-config-guide-v67/device_management_basics.html
again read about this command before apply
thanks
MHM
As said in this guide https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp2100/firepower-2100-gsg/ftd-fmc-remote.html#task_imq_yw3_b3b
 1 step I am configuring my private static ip in initial setup with default route by data interfaces
2 step i am typing  > configure network management-data-interface
Ether 1/1 outside interface
Ip mask gw of my ISP
3 step i am typing configure manager add DONTRESOLVE Cisco-123 nat123
sheralimamatkarimov_0-1705518885123.png there are two tunnel one is control and other is event
so
point to check
1- Check the Ver. is compatible or not between FTD and FMC
FTD /ngfw/var/log/messages file:
2- share this
> capture-traffic
Please choose domain to capture traffic from:
  0 - eth0
  1 - Global
Selection? 0
Please specify tcpdump options desired.
(or enter '?' for a list of supported options)
Options: -n host <FMC IP>
 MHM
Thank you for answer but i decided to manage remote office FTD bt FDM, I configured all but i have one small problem i will open new discussion for it.
lki
Make sure CPU monitoring of the FMC's Health Policy is enabled
Try to disable CPU monitoring
Shamrock
After you change the config network ipv4 manual ip subnet data-interfaces, and configure network data-management-interface, a working configuration for me was ensuring you have a NAT outbound and separate NAT inbound on your FMC side (assuming FMC is behind NAT).  I was getting the timeout without the NAT inbound to FMC.  Also, configure manager add "extIP" "key" "NatID" was the right combo.
