FWSM connection issues
clark-white
I have a stange issues with FWSM, find the attached diagram
I'm trying to connect to remote site server on a specific IP from my server. when i do telnet on port 80 from my windows server it works fine but for port 443,1919 it doesnt works, when i bypass the FWSM all port open without any issues.
Strange   when i start packet captures on FWSM and at the same time initiating a telnet 10.27.27.27 80 on windows server i dont see the return traffic in the capture by the destiantion server but the connection completes in windows. the same when i do for the telnet 10.27.27.27 443 it fails below are the capture logs for 443 and  logs for port 80.
19: 13:25:45.765044970 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.443: S 901281170:901281170(0) win 8192 <mss 1460,nop,wscale 8,nop,nop,[|tcp]>
  20: 13:25:48.765047980 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.443: S 901281170:901281170(0) win 8192 <mss 1460,nop,wscale 8,nop,nop,[|tcp]>
  21: 13:25:54.765053980 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.443: S 901281170:901281170(0) win 8192 <mss 1460,nop,nop,sackOK>
19: 13:25:45.765044970 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.80: S 901281170:901281170(0) win 8192 <mss 1460,nop,wscale 8,nop,nop,[|tcp]>
  20: 13:25:48.765047980 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.80: S 901281170:901281170(0) win 8192 <mss 1460,nop,wscale 8,nop,nop,[|tcp]>
  21: 13:25:54.765053980 802.1Q vlan#16 P0 10.221.221.221.62481 > 10.27.27.27.80: S 901281170:901281170(0) win 8192 <mss 1460,nop,nop,sackOK>
clark-white
Anybody can help me on issue above
