FWSM not working please help
NAVIN PARWAL
Level 2
Level 2
Folks,
I am configuring inter chassis, failover which I have gotten to work many times, but today for some reason I am unable to work. Please help me, vlan 30 is failover vlan whis is passing netween the 2 swicthes, but for some reason the FWSM disables failover whenever I enable it, very stange?????
Switch
no aaa new-model
firewall multiple-vlan-interfaces
firewall module 3 vlan-group 1
firewall vlan-group 1 30,40,211,311,411
ip subnet-zero
FWSM#
FWSM# show run
: Saved
FWSM Version 3.2(2)
hostname FWSM
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan30
description LAN Failover Interface
interface Vlan211
nameif inside
security-level 100
ip address 172.16.11.2 255.255.255.0 standby 172.16.11.222
interface Vlan411
nameif outside
security-level 0
ip address 192.168.1.1 255.255.255.0 standby 192.168.1.111
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
pager lines 24
mtu inside 1500
FWSM# show failover
Failover Off
Failover unit Primary
Failover LAN Interface: failover Vlan 30 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 0 of 250 maximum
FWSM# conf t
FWSM(config)# fail
FWSM(config)# failover
FWSM(config)# end
FWSM# show fail
FWSM# show failover
Failover Off
FWSM#
hadbou
Level 5
Level 5
The problem might be the mismatch VLAN assignment across the firewall (FWSMs and supervisors). For example, in the Firewall vlan-group 1 statement, the same number of VLANs assigned on each switch to the firewall can vary. This might cause the issue. If you assign the same number of VLANs in the firewall, then failover will work.
In order to avoid getting a VLAN configuration mismatch error, the show vlan command output must be identical on both FWSMs. This error message only occurs when you modify or load the failover configuration on the FWSM. For example, when a FWSM boots it loads the startup-config from the flash and attempts to initialize failover. At this time, it checks to make sure both modules are receiving the correct VLANs. If the VLANs do not match, the error message is displayed and failover remains disabled.
Note: For failover to work, the FWSM requires identical configurations and port assignments. It is possible to do inter-chassis failover, but each VLAN assigned to the firewall must be in the trunk between the two chassis.
FWSM does not include any external physical interfaces. Instead, it uses VLAN interfaces. Assigning VLANs to the FWSM is similar to assigning a VLAN to a switch port. The FWSM includes an internal interface to the Switch Fabric Module (if present) or the shared bus.
Be aware that the VLAN mapping can get modified during a working FWSM setup and will fail during next boot.
