FWSM & PAT & static NAT & port forwarding problem
oreggin80
Hy!
On our FWSM there are some PAT about ~500 hosts. The DNS server should have a static NAT, some servers should have some port forwarding. I set those but DNS server & other servers can access only from VLAN60. Offices's PAT is work fine but I can't access mapped IP from other VLANs.
VLAN60 : 13.25.60.0/22
VLAN518: 172.18.0.0/16
IP of DNS server: 172.18.255.2 (should have 13.25.60.1)
IP of server1: 172.18.250.1
IPs of Offices: 172.18.0.1-172.18.2.254
Mapped IP: 13.25.60.239
FWSM conf. part. example:
nameif vlan60 outside security1
nameif vlan518 offices security51
access-list NAT extended permit ip any any
access-list static1 extended permit tcp any host 13.25.60.239
access-list static1 extended permit ip any host 13.25.60.1
ip address outside 13.25.63.244 255.255.252.0
ip address offices 172.18.255.254 255.255.0.0
global (outside) 1 13.25.60.2
global (outside) 2 13.25.60.3
global (outside) 3 13.25.60.4
nat (offices) 1 172.18.0.0 255.255.255.0 tcp 0 120
nat (offices) 2 172.18.1.0 255.255.255.0 tcp 0 120
nat (offices) 3 172.18.2.0 255.255.255.0 tcp 0 120
static (offices,outside) 13.25.60.1 172.18.255.2 netmask 255.255.255.255
static (offices,outside) tcp 13.25.60.239 22 172.18.250.1 22 netmask 255.255.255.255
access-group static1 in interface outside
access-group NAT in interface offices
route outside 0.0.0.0 0.0.0.0 13.25.63.254 1
oreggin80
Hy!
I added this to config:
global (outside) 13 13.25.60.239
nat (offices) 13 172.18.250.0 255.255.255.0 tcp 0 120
static (offices,outside) tcp 13.25.60.239 ssh 172.18.250.1 ssh netmask 255.255.255.255
static (offices,outside) tcp 13.25.60.239 44444 172.18.250.1 44444 netmask 255.255.255.255
Now, I can access the backup server of offices from everywhere I would like, and the internet works on the server too.
