Global IP communications problems with outside interface
anders.lindback
Hi all. I have small problem I need help to figure out
I have a Global statement:
global (outside) 2 1.1.1.10 netmask 255.255.255.240
And my nat statement is:
nat (dmz2) 2 0.0.0.0 0.0.0.0 0 0
Now, I have a host inside DMZ2 that wants to talk to my PIX's outside interface which is: 1.1.1.3
So the traffic goes from insidehost -> gets PAT/NAT with 1.1.1.10 (global interface) and then trying to contact the real outside interface 1.1.1.3. But it dont work
In my DMZ2 ACL i have the rule "permit ip any any" just to be on the safe side.
My insidehost can contact other sites outside my PIX. (I Have 2 other pix with other ip-ranges that the inside host can contact without problems.)
So, is it possible for the global interface to contact the outside interface or is that denied somehow intentionaly`?
Or do i need to add a rule in the outside ACL that permits the outside interface to communicate with the global interface?
Anders
vitripat
Level 7
Level 7
This wont work. But why exactly do you need a DMZ host to communicate with PIX's outside interface IP address? If you can tell the requirement like a webserver on inside using PIX's outside interface IP address, we may be able to help.
Vibhor.
hi
might have figured something out, gonna test and come back later
brb
It is recommended to use static nat translation for servers within a DMZ, for example.
static (dmz,outside) 66.44.44.33 192.168.1.1 netmask 255.255.255.255
If 192.168.1.1 (real address) is a webserver, then do:
access-l outside_in permit tcp any host 66.44.44.33 eq 80
access-group outside_in in interface OUTSIDE
