Help enable 3389 from DMZ to Inside
awhadmin
I'm using Pix 520 rev 4.2
I need to enable a computer in the DMZ RDP access to computers (entire scope) behind the INSIDE interface. How can i do this?
Ex. Machine (192.168.4.5/24 only) in DMZ needs to RDP into Machines (172.16.5.x/21) on the INSIDE network.
BTW: I'm limited to the "Conduit Permit" command
Kureli Sankar
You need static (inside,dmz) 172.16.5.0 172.16.5.0 netmask 255.255.248.0
Then you need to allow the DMZ hosts via an ACL to reach the inside hosts on port 3389.
-KS
Jennifer Halim
With the static configuration that kusankar advise, here is the conduit configuration:
conduit permit tcp 172.16.5.0 255.255.248.0 eq 3389 host 192.168.4.5
Hope that helps.
