Help with ACL on ASA 5505
scott.maron
Hi all,
Looking for some assistance with creating an ACL to allow traffic both ways for a device.  We have an ASA 5505 for our VPN, however there is a device on our network that needs to be monitored from the vendor.  I have an open IP from the ISP that i'm going to use for a static NAT to that device, but I can't seem to get the access control list correct to allow traffic through from one specific external IP running through a pre-defined port.  I also need port 80 traffic through from an external range.
Thanks for any help
-Scott
Panos Kampanakis
Scott,
Your ACL apllied on the outside of the ASA should be
access-list permit tcp host host
access-list permit tcp host 80
And of course I would expect you to have a static like
static (inside,outside)
I hope it helps.
PK
