Help with basic config for ASA 5505
Andy White
Level 7
Level 7
I've tried so many config methods I'm not confused on the issue.
I have a DSL modem from Virgin Media and if I plug my laptop into it it gives me a public IP and I can get on the internet, it is doing some sort of DHCP.  Now I have put the outside of the firewall into this port and configured the ASA as best as I can but I can't get on the internet from the inside, can you think of any reason why it isn't working?
ASA Version 9.1(3)
hostname ciscoasa
enable password RHohe4nol/SZU8wm encrypted
names
interface Ethernet0/0
switchport access vlan 99
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan10
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan99
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-network
access-list inside_access_in extended permit ip 192.168.0.0 255.255.255.0 any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcp-client client-id interface outside
dhcpd auto_config outside
dhcpd address 192.168.0.10-192.168.0.254 inside
dhcpd dns 4.2.2.2 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password /duR4QE encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
20 Replies 20
Thanks, that makes sense to me know.
Also why did the mac address insertion fix my main issue on the outside interface? (whoops I see you replied to this already)
Message was edited by: Andy White
Marius Gunnerud
Before reloading the ASA, have you tried flapping the outside interface (shut, no shut)?
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
No luck with the "shut" "no shut" I'm afraid.  I will proceed with the debug and captures.
When I google Virgin Media and ASAs it seems it can be done, but like you say it could be a version issues too.  Will be back later with some more info, thanks guys.
Some ISPs might filter vendors as they only wish for you to connect a PC  not a router/firewall or whatever device that will provide access to  more than one PC.
Value our effort and rate the assistance!
Any other option would require troubleshooting and it could be related to layer 2.
Very detailed reply
