Help with EIGRP on ASA and site-to-site VPN
burleyman
Level 8
Level 8
I have a core switch running EIGRP and it connects to the ASA which also has EIGRP running. How can I setup EIGRP so the Site-to-Site VPN subnets are propagated throughout the EIGRP AS? ASA is running 8.2(5).
Mike
Jon Marshall
Hi Mike
I have never used it but Reverse Route Injection will automatically add static routes for your VPNs and inject them into a dynamic routing protocol for you.
According to this link from ASA 8.x it is also supported for EIGRP -
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/107596-asa-reverseroute.html
like I say never used it so can't say for sure how well it works.
if it doesn't work then you could either -
1) add statics to the ASA and manually redistribute into EIGRP
or
2) add statics to your core switch pointing to the ASA for the remote networks
so a number of options and one of them should work at least.
Jon
That is where I was going but thought I would check to make sure there was not something I missed. I have used Reverse Route Injection and it does work great.
Now I should not add the subnets in the "Network" statement under EIGRP correct, just redistribute the Static routes?
Thanks Jon, hope things are going good for you. Oh yeah, Go Flames! that is still your team right?
Mike
Correct.
Hope your good as well.
Edit - football for me and I think you know who my team are :-)
Jon
