help with PIX-501 example
bbensoncisco
Community Member
Hello all,
I'm learning how to configure a PIX 501. The boss said "you can do this right?", "I guess", I said and he said "good, please make it work".
Well I found an example:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094ea2.shtml
that has most of what I need but I can only get small things to work.
Currently I have two hosts on the inside network, a linux workstation at IP 1.220 and a linux web server @ 1.4.
I have a Windows PC which I can use to test the connections on the inside network or the outside.
When the PC is on the inside at 1.66, I can get to the web server. I see in the server logs the request from the PC and the responses from the server and I see the page on my browser.
When I move the PC to the outside network @ 10.2.1.201, I see the PIX NAT the destination address of the web server from 10.1.1.3 to 192.168.1.4 as expected but the web server never gets the request.
I can ping the router at 10.1.1.1 and the PIX at 10.1.1.2 from the outside but no farther inside.
The only change I have made to the example was to enable all the ICMP traffic and change the telnet host to 1.220:
pixfirewall(config)# sho icmp
icmp permit any outside
icmp permit any inside
pixfirewall(config)# sho telnet
192.168.1.254 255.255.255.255 inside
192.168.1.220 255.255.255.255 inside
From the PIX logs:
Feb 20 10:01:25 192.168.1.1 %PIX-6-302013: Built inbound TCP connection 11 for outside:10.2.1.201/3897 (10.2.1.201/3897) to inside:192.168.1.4/80 (10.1.1.3/80)
Feb 20 10:03:26 192.168.1.1 %PIX-6-302014: Teardown TCP connection 11 for outside:10.2.1.201/3897 to inside:192.168.1.4/80 duration 0:02:01 bytes 0 SYN Timeout
So I have three questions:
1. Is anyone aware of a bug or typo in the example I used above?
2. Can someone direct me to a manual on how to configure the logging to show what is happening to my packets? NATs, routes used etc.
3. How can I turn my PIX into an expensive router, i.e. turn off all firewall stuff and let everything through from inside to outside and back?
Thanks in advance for any help,
Brian
Ivan Martinon
Level 11
Level 11
So what you are trying to do is to have this webserver reached from the outside? If this is the case you need static translations and access-lists, can you post your pix configuration here?
That is correct.
access-list 100 permit icmp any any echo-reply
access-list 100 permit icmp any any time-exceeded
access-list 100 permit icmp any any unreachable
access-list 100 permit tcp any host 10.1.1.3 eq www
access-list 100 permit tcp any host 10.1.1.4 eq smtp
access-list 100 permit tcp any host 10.1.1.5 eq ftp
logging on
logging standby
logging monitor debugging
logging trap debugging
logging host inside 192.168.1.220
ip address outside 10.1.1.2 255.0.0.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
arp timeout 14400
global (outside) 1 10.1.1.254
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 10.1.1.3 192.168.1.4 netmask 255.255.255.255 0 0
static (inside,outside) 10.1.1.4 192.168.1.15 netmask 255.255.255.255 0 0
static (inside,outside) 10.1.1.5 192.168.1.10 netmask 255.255.255.255 0 0
access-group 100 in interface outside
route outside 0.0.0.0 0.0.0.0 10.1.1.1 1
Thanks for your help.
If the 10.1.1.X is the internal range, then you got these wrong:
They should be
static (inside,outside) 192.168.1.4 10.1.1.3 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.1.15 10.1.1.4 netmask 255.255.255.255 0 0
static (inside,outside) 192.168.1.10 10.1.1.5 netmask 255.255.255.255 0 0
And your ACL statements are wrong too:
access-list 100 permit tcp any host 192.168.1.4 eq www
access-list 100 permit tcp any host 192.168.1.15 eq smtp
access-list 100 permit tcp any host 192.168.1.10 eq ftp
That is how they should look.
