Help with PIX 501 Static IP
guydestefano
I currently have a static IP address thru Sprint. I can verify it thru any number of ( whatismyip ) type web pages. It hasn't changed in over three months. I had received help thru this board in setting up my pix config to accept this static ip. I can search the Internet via DSL really great, with no problems. I do not have a seperate router. I have two computers connected thru two of the four ports behind the PIX 501. Both computers share everything, again no problems. No one seems to be able to ping my static IP address from outside my computers. I can't ping it, of course from inside. I have purchased a domain name, then thru zoneedit.com, the swap from the domain name to my static ip address, it is triple checked. I am usimg webweaver server, again setup correctly. Cannot enter my server from outside. It seems like my static ip address is being stopped at the pix, yet all internet explorer activity gets thru. Is there any thing I can try to see if when I enter www.guydestefano.com, the DNS servers supposed to direct it to my static ip, and can I trap it etc.. to see if it actually gets here. The server is running, and never gets anything. Any help will be greatly appreciated. I have been trying for weeks now, and not getting any closer. Thanks in advance.
8 Replies 8
mostiguy
Level 6
Level 6
Out of the box the pix blocks all icmp (which includes icmp echo request and reply)
icmp permit 0.0.0.0 0.0.0.0 echo-reply outside
should allow the outside interface to reply to ping requests.
mostiguy It wouldn't accept that command. I had one that stated [ icmp permit any unreachable outside ],
this was given to me by someone on a prior board. Any other suggestions I might try. Thanks again for the reply.
Try - icmp permit any outside
Jay
Jay, Thank you very much for the reply. I entered your instruction, and it did allow outside pings. I use www.grc.com to check it out, and it said I failed the test, as icmp pings were allowed in. I then tried to enter my domain name, and it waited a few seconds and then said page could not be displayed. Webweaver server is in and running, I use GFI Network Security program, and it stated server as running. I checked all DNS links again, and all looks ok. I will keep trying. Here is my PIX config, it may be something else. Thanks again very much.
pixfirewall>
en
Password:
pixfirewall# config t
pixfirewall(config)#
pixfirewall(config)# wr t
Building configuration...
Cryptochecksum: ***********
[OK]
Saved:
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ***** encrypted
passwd *********** encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 64.45.231.21 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 64.45.231.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:***************
end
[OK]
Sounds like you want to do a couple of things:
1) ICMP Traffic permitted to Ping Outside Interface
2) Allow WWW traffic to webserver on inside
access-group OUTSIDE in interface outside
access-list OUTSIDE permit icmp any any
access-list OUTSIDE permit tcp any host IP-of-WWW eq www
static (inside,outside) tcp 64.45.231.21 80 IP-of-WWW 80 netmask 255.255.255.255
Try this and then perform a "clear xlate" then try to connect to your web server. Make sure to change the above config for the right IP of your WWW server.
You may need "icmp permit any outside" to allow anyone to ping the outside interface of your 501.
Let us know how this does ....
peter
pcomeaux, Thank you very much for your reply. I have made all the changes you have suggested, and have enclosed the new PIX listing. I have one question, where you state to change the IP-of-www, With WinXPPro, In tcp properties, the ip address is 192.168.1.2 the other machine is 192.168.1.3, the web server will only be on 192.168.1.2.
The output from www.grc.com is:
Your computer at IP:
64.45.231.21
Is being profiled. Please stand by. . .
Ping Reply: RECEIVED (FAILED) — Your system REPLIED to our Ping
(ICMP Echo) requests, making it visible on the Internet.
Most personal firewalls can be configured to block,
drop, and ignore such ping requests in order to better
hide systems from hackers.
This is highly recommended since "Ping" is among the
oldest and most common methods used to locate systems
prior to further exploitation.
wr mem
Cryptochecksum: *****************
[OK]
wr t
Saved:PIX Version 6.3(1)
enable password ********************
names
access-list OUTSIDE permit tcp any host 192.168.1.2 eq www
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
static (inside,outside) tcp 64.45.231.21 www 192.168.1.2 www netmask 255.255.255.255 0 0
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:****************
end
[OK]
Change the IP in the following ACL:
from 192.168.1.2 to 64.45.231.21 and your web page should load from remote sites.
Give this a try and let us know.
Also, looks like ICMP is working as I can ping the outside of your firewall.
thanks
peter
pcomeaux, Again, thank you very must for your help, and staying with me on this problem. Sorry for the late response, as I just got home. Below is the few lines from the updated instructions I just entered, I just remembered, I did not do a clear xlate after I did the changes, is that required. I think I will leave all the instructions that you gave me, As long as you can ping my computer, I think I am going to try another server. I feel that the PIX is great now, so my problem may be with webweaver server. Again, thank you very much for all of your help.
Guy
names
access-list OUTSIDE permit tcp any host 64.45.231.21 eq www
pager lines 24
