How to access firepower through outside interface using ASDM
wael Kamal
Dear experts,
I have ASA 5506X  and I configure the ip address of firepower module and inside in the same subnet and i can access it using ASDM but from inside but from outside the ASDM  give me i can't access ip address of firepower doesn't show firepower tab
Jetsy Mathew
Hello Kamal,
First of all confirm that you have followed any of the following deployment method mentioned in the link.
http://www.cisco.com/c/en/us/support/docs/security/ips-sensor-software-version-71/113690-ips-config-mod-00.html   (also applicable for sfr)
Let me know which kind of deployment that you have from above link.
Kindly rate if the post helps you
Jetsy
Jetsy Mathew
Hello Kamal,
Jetsy
