How to allow all outgoing traffic and block all incoming traffic with access list?
N5fGc9uYr
Using Cisco PIX 515E firewall
Version 7.2(4)25
Unrestricted (UR) license
This is my current configuration:
config t
int e0
ip address dhcp setroute
nameif outside
no shut
int e1
ip address 10.1.1.1 255.0.0.0
nameif inside
no shut
exit
global (outside) 1 inter
nat (inside) 1 10.0.0.0 255.0.0.0
icmp deny any outside
For outbound traffic:
access-list Inside_allow_all permit ip any any
access-group Inside_allow_all in interface inside
For inbound traffic
access-list Outside_Restricted deny ip x.x.x.x x.x.x.x
access-group Outside_Restricted in interface outside
Puneesh
Please rate helpful posts
5 Replies 5
Puneesh Chhabra
When you name the interface as "inside", it automatically acquires the security level 100 and outside would be 0.  So, by default all outgoing traffic is allowed and incoming is blocked.
If you want to do it explicitly, you can specify ACLs and apply them on the interface.
Puneesh
Yes I know how to do it by using security levels inside 100 and outside 0.
But for educational purposes I wanted to know how to do it explicitly via access list in a simple way.
No fancy setups if possible.
For inbound traffic
Puneesh
For inbound traffic:
The deny ip x.x.x.x x.x.x.x should be?
my local ip
my public ip
my private ip
my gateway
dhcp setroute
any any
I use any any in x.x.x.x x.x.x.x
It took all the commands properly
Thanks, great support
