05-07-2003 11:07 AM - edited 02-20-2020 10:43 PM
I just configure PIX 515E ,clients can connect to the internal network,
but cannot reach the internet,
how to configure PIX 515E to enable split tunnel
05-07-2003 11:42 AM
HI.
You're using PPTP, and the remote WIN2000PRO is the PPTP client, while the pix is acting as PPTP server. Is this correct?
If so, then the best solution is to transit to Cisco IPSec VPN with split-tunnel.
PPTP does not have this option - you can disable the "use remote network as default gateway" at the client, but this will probably prevent access to your internal network.
There are other possible solutions, like terminating the VPN on an internal server instead of the pix, or using proxy/terminal server..
But the best IMHO is to use Cisco IPSec client, because it can be configured with better security then PPTP, and can solve your split tunnel problem.
Yizhar
05-07-2003 06:08 PM
Once I have enter site,and customer show me the split tunnel on PPTP
for the other company, so I think it would be exist,but I don't know how
to do...I will meet the customer again this morning,and he will tell me
how to work split tunnel on Win2k without configure default gateway on client.
