how to know the speed of traffic in an interface CISCO ASA
Luis Carranza
Hi!!
I want to know if there any command to know how many traffic per second goes through an interface, we got some issues with overruns and we want to knoe that info. If anybody knows something that will be really helpful.
Regards.
varrao
Level 10
Level 10
Hi Luis,
To check that you can use qa couple of commands:
show interface
show traffic
this would give you the right data that you need.
Hope  this helps.
Varun
Varun Rao
varrao
Level 10
Level 10
Hi Luis,
show interface
show traffic
Hope  this helps.
Varun
Varun Rao
