How to reconfigure ip-block on Firepower Management Chassis
I am in the process of setting up a new Firepower 9300. However, I accidentally misconfigured the IP block settings while trying to bring up the chassis manager, and now I cannot connect via HTTPS or SSH. How can I reconfigure the IP block to allow HTTPS access to the chassis manager?
Currently I am connected via Console/serial connection
This issue is resolved using the link: https://community.cisco.com/t5/network-security/can-t-access-fcm-after-re-imaging-and-initial-setup/td-p/4588406
nspasov
You have two options:
  1. Serial Console
  2. Directly attach a computer to the mgmt interface > Configure a static IP on the computer that is in the same subnet as the mgmt interface
Thank you for rating helpful posts!
