How to resolve Deny TCP (no connection) ACK and FIN ACK messages
jgrubbs
We currently have an ASA running 7.2(2).  We have NAT rules setup to change XXX.XXX.93.106 to 10.70.8.31 on port 636 for external LDAP connection.  This rule is working without a problem for two of our external websites.
We are trying to connect to another site but I continue to receieve these messages:
6    Dec 16 2010    10:31:49    106015    75.126.254.94    xxx.xxx.93.106     Deny TCP (no connection) from 75.126.254.94/57631 to xxx.xxx.93.106/636 flags FIN ACK  on interface VPN_Outside
6    Dec 16 2010    10:31:49    106015    75.126.254.94    xxx.xxx.93.106     Deny TCP (no connection) from 75.126.254.94/57631 to xxx.xxx.93.106/636 flags ACK  on interface VPN_Outside
Here are the rules allowing traffic on port 636:
access-list VPN_Outside_access_in extended permit tcp object-group Wikispaces_LDAP host xxx.xxx.93.106 eq ldaps
Here are the IP addresses in Wikispaces_LDAP:
object-group network Wikispaces_LDAP
network-object host 75.126.102.45
network-object host 75.126.254.94
network-object host 208.43.219.254
network-object host 75.126.102.43
network-object host 208.43.219.251
network-object host 75.126.254.93
network-object host 75.126.102.44
network-object host 75.126.254.92
network-object host 208.43.205.127
network-object host 66.228.116.239
network-object host 208.43.219.250
Any ideas?
Kureli Sankar
Jason,
Could you pls. get the syslog for built and teardown for the same 4-tuple?
same sourceIP dest IP and source port and dest port.
-KS
v6    Dec 16 2010    10:31:49    302013    75.126.254.94    10.70.8.31     Built inbound TCP connection 89414924 for VPN_Outside:75.126.254.94/57631 (75.126.254.94/57631) to Inside:10.70.8.31/636 (xxx.xxx.93.106/636)
The next two messages are the ones I already posted.  There is no teardown of the connection.
There has to be teardown syslog - 302014. Unless you are not logging that message - do you have "no logging message 302014"?
If so pls. remove that.
I believe you are seeing those 106015 messages because those packets are arriving after the conn has been torn down.
-KS
