How to use FTD 2140 data interface for management [HA]
Lamin
Hi All,
I have deployed 2x FTD 2140 in a HA mode. These are managed by FMC (version 7.2.3).
What i am try to achieve is configure one of the data interfaces on each FTD to use as inband management interface. I will like to use this data interface for FMC <> FTD (TCP 8305) management and also for normal inband management access. I still want to keep management 1/1 for local access (oob) without a default gateway.
I am not sure how this should be done but i have tried to configure the data interface via FMC but option to set to 'management only' frozen
I also tried via FTD using the below command but it errored:
> configure network management-data-interface ipv4 manual 172.16.1.1 255.255.255.248 interface Ethernet1/10
Error: The interface: Ethernet1/10 is not configured with remote management
Below is my physical topology. FMC is not included but it's communicating with FTDs via FTD management 1/1.
Lamin
As per the below documentation, "High Availability is not supported. You must use the Management interface in this case" for ftd remote management
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp2100/firepower-2100-gsg/ftd-fmc-remote.html
Lamin
This is from the config guide regarding management on the date interface:
  • High Availability is not supported. You must use the Management interface in this case.
https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/management-center/device-config/730/management-center-device-config-73/get-started-device-management.html
Did you mean that we can have two separate IPs for the FTD HA management through DATA interface?
One IP for the Active firewall and second IP for Standby firewall? Through Standby IP can i manage the standby FW.
Do you have any documentation to perform this configuration?
