HTTP inspection problem
Hi, I have configured IOS Zone Based Firewall on my office 871 router.
I've made an inspection rules for http, https, icmp and dns for in-out zone. Often I can see in router log the message:
%APPFW-3-HTTP_MAX_REQ_EXCEEDED : Number of unanswered HTTP requests exceeded the limit 10.
I guess this is becouse there are about 7 people working simultaneously and some of them use skype, witch probably makes unanswered sessions.
However, i want to ask, is there some way to change the limit of 10 unanswered request?
Thanks in advance!
The limit is raised to 64 in 12.4(20)T.You can give a try with that.
7 Replies 7
ivillegas
Level 11
Level 11
This error message means firewall sees 10 outstanding requests without any reply over a single TCP connection. Normally this shouldn't happen unless you have huge delay in the network or the HTTP server is very slow in responding to the request.
Thanks for reply!
I understand what the error message means, but I don't know how to prevent it.
I'm sure that it's NOT from the network delay or internet connection speed (ADSL - 12Mb/s).
I need to increase the limit number of 10 unopened connections. Is this possible?
Thanks!
sadsiddi
Level 2
Level 2
What version of IOS do you use now?
my version of IOS is 12.4(15)T with Advanced Ip services, and i've configured a Zone-Based-Firewall
Thank you very much, I'll try it next week and i hope that will helps me..
Henry Gonzales
Frequent Visitor
Frequent Visitor
I also have the some problem.
I have: c1841-advsecurityk9-mz.124-4.T7.bin - Version 12.4(4)T7
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
I have to upgrade IOS?
Thanks in advance!
