IDM problem
tareqrebhi
Level 4
Level 4
dear....
i was able to use IDM before but after i upgarde the IPS from 5.1.5 image to 5.1.5E i lost and can not connect to sensor using IDM as before i enabled web tls port 8080 .....now i only use CLI to configure the IPS but i need to use IDM.....do you have any suggestions?
thanx........
sadbulali
Level 8
Level 8
Make sure you have the following options checked/unchecked for the following menus in the web browser
JAVA SUN
+ Use JRE 1.4.1 (unchecked)
Microsoft VM
+ Java console enabled (unchecked)
+ Java logging (unchecked)
+ JIT compiler(checked)
Also check if you have the patch PS-K9-patch-5.1-1p1.pkg installed.
mhellman
Level 11
Level 11
It sounds like you don't have any connectivity at all? Have you tried connecting on the default port 443? Cisco upgrades have a nasty habit of tossing non-default settings during an upgrade.
