Impact to decrease tcp idle connection timer on system
Otgonbayar Mijiddorj
Community Member
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
As i understood, timeout conn is idle session timeout not a session lifetime. Am I correct?
if so, what are the impacts on system to decrease idle session timeout?
I heard that more hardware resource will be required to create a connection again on the system if we set low value for idle conn timer. is that correct?
Thanks.
Oogii
Damm.
I would halve the "half-closed" number from 10 minutes to 5 minutes.
Philip D'Ath
Meraki Community All-Star
The first question is what problem are you trying to solve?  Why would you want to do this?
Hi Philip,
Number of connection is reached the limit of my ASA firewall. That is why I am looking for solution to decrease number of connection to tune tcp idle time. And i would like to know impacts on system to decrease idle session timeout.
oogii
Damm.
Thanks Philip,
That would be help to decrease number of connection and it has lower impact.
