Inside users not able to ping to outside interface ip.
prashantrecon
We are not able to ping  to  the outside interface of the firewall from inside network (lan network).(ie trafic directed at the interface)
I have executed the command icmp permit any echo-reply outside
                                            icmp permit any echo outside.
Still we are not able to ping outside interface.
I have also created the accesslist so that the internet user are able to ping to outside interface of the firewall .This is working fine.
Please suggest so that inside users should be able to ping outside interface.
8 Replies 8
varrao
Level 10
Level 10
Hi Prashant,
Due to security features of the ASA, you would never be able to ping remote interfaces on the ASA, which means no ping would work from inside LAN to outside interface and from internet to inside interface. This is not possible.
You would only be able to ping inside interface from LAN, or the default gateway for the firewall, if you are afcing any issues with pinging the internet ip's from the LAN, let me know.
Hope this was useful.
Varun
Please do rate helpful posts.
Varun Rao
As mentioned in Richard Deal book he has explained the topic called called trafic directed at the interface .
Could u please clear this.
Hi Prashant,
I am not sure about what is written in the book, haven't read it but what it may be indicating is the ASA interface to which the LAN machines are connected to. Can you paste the excerpts from the book, because  am sure it does not mention anything about the remote interfaces, this is not possible and cannot be done. Do let me know if you have any doubts.
Hope this helps
Varun
Varun Rao
Could u please explain the below concept
Restricting ICMP Traffic Directed at the Appliance
The remainder of this section will focus on using the ICMP filtering feature. To control
ICMP messages destined to an interface on the appliance, use the icmp command:
ciscoasa(config)# icmp {permit | deny}
src_IP_address src_subnet_mask
[ICMP_message_type] logical_if_name
You must specify a source IP address and a subnet mask. Unlike with an extended ACL,
there is no destination IP address, because the security appliance, itself, is the destination.
You can qualify which ICMP messages are allowed or denied by entering a value for
the ICMP_message_type parameter. The message types can be entered as either a name
or a number. If you omit the message type, the appliance will assume that you want to allow
or deny all ICMP messages. The last parameter is the name of the interface for which
you want to restrict ICMP messages.
The appliance processes the icmp commands top-down for an interface. In other
words, when the appliance receives an ICMP packet destined to one of its interfaces, it
checks to see if any icmp commands are associated with the interface. If none is defined
for the interface, the appliance processes the ICMP message and responds with the appropriate
ICMP response. If an ICMP filter is on the interface, the appliance processes
the icmp commands based on the order in which you entered them. If the appliance goes
through the entire list and doesn’t find a match, the appliance drops the ICMP message;
this is like the implicit deny statement at the end of an ACL.
To remove a specific icmp command, preface it with the no parameter. To delete all the
icmp commands that you have configured, use the clear configure icmp command.
NOTE As with ACLs, an implicit deny is at the end of the icmp command list. Therefore, if you use
the icmp command, you should at least specify one permit statement per interface, unless you
want your appliance to be completely invisible from ICMP traffic on the specified interface.
ICMP Filtering Example
Now let’s take a look at an example on how to use the icmp command to restrict ICMP
messages directed at an appliance interface. In this example, you want to be able to test
connectivity from the appliance to other destinations on the Internet, and you want the
appliance to process only certain ICMP packets to aid in connectivity testing—all other
ICMP messages should be dropped. Here’s an example of how to accomplish this:
ciscoasa(config)# icmp permit any conversion-error outside
ciscoasa(config)# icmp permit any echo-reply outside
ciscoasa(config)# icmp permit any parameter-problem outside
ciscoasa(config)# icmp permit any source-quench outside
ciscoasa(config)# icmp permit any time-exceeded outside
ciscoasa(config)# icmp permit any unreachable outside
ciscoasa(config)# icmp deny any outside
Hi Prashant,
Whatever explanation you see in this is for this case, if the host is connected to that interface only, which means:
Users on the internet need to ping outside interface
users in the lan need to ping inside interface
nowhere it is written that you can ping outside interface from the inside network lan, it is only if you are behind that interface. Don't worry you can take our word on this for the Cisco ASA
Varun
Varun Rao
Thank you varun,
My doubt is cleared now.
No issues
You can mark this thread as answered and do rate helpful posts.
Varun
Varun Rao
Jennifer Halim
Yes, that is the correct default behaviour.
You will not be able to ping the opposite interface of the firewall.
Eg: if your PC is connected to the inside interface, you can only ping the inside interface of the firewall, or anything through the firewall, but not any other interfaces but inside interface of the firewall.
If you want to ping the firewall outside interface, you can ping it from the internet only.
