nating problem
learnsec
Level 5
Level 5
dear all,
problem: node A(located inside)- having ASA as a gateway- cannot reach ntp server(located inside)
this is the scenario:
node A located in the Inside Zone.
NTP Server(router) Also Located in the inside Zone.
on node A i have (for certain reason) i had to change its gateway and set it to be the ASA. and i cannot add a static route on node A. once this done node A Cannot reach anymore NTP Server.
although if i Ping NTP Server ip address(inside ip) from the ASA itself the reply is successfull.
node C located on DMZ and node D Located on Outside zone on the same ASA can successfull synchronyze with the ntp Server(with natted ip address)
can you explain more how to troublshoot this issue in order to let node A ping NTP Server in order to synchronize time?
The statement :
static (inside,inside) 10.150.1.1 10.150.1.1 norand nailed
is specific only to 10.150.1.1 server only, so it should not hamper any other traffic. If you have any other questions do let me know.
Varun
Varun Rao
7 Replies 7
varrao
Level 11
Level 11
You are trying to u-turn the traffic on the ASA interface, which means traffic coming from inside needs to turned back (if ASA is teh default gateway), so you would need the following statement for it:
lets say node A network is 10.1.1.0
and ntp server real ip is 10.150.1.1
so you would need:
static (inside,inside) 10.150.1.1 10.150.1.1norand nailed
nat (inside) 5 10.1.1.0
global (inside) 5 interface
same-security-traffic permit intra-interface
and it shoudl work after this. Let me know if you have any issues.
Varun
Varun Rao
hello varun,
i think even if ASA can reach (though ping) the NTP Server and the Node A network,
but also i have to add a static (inside, inside).
but shall i ahve to add
nat (inside)
global (inside)
or enough to add the static?
finally what do you mean by :
"same-security-traffic permit intra-interface"?
Yes yu would need the nat and global statement as well.
The same security command would permit traffic whose source and destination is behind the same interface and it is a very important command in case of u-turning the traffic.
Hope this helps.
Varun
Varun Rao
can i permit specific traffic to communicate between source and destination that is behind a certain defined interfaces?
for example inside?
to avid any side effects that may occurs
The statement :
Varun
Varun Rao
Norand nailed is what for?
Here's the explanation:
http://www.cisco.com/en/US/customer/docs/security/asa/asa82/command/reference/s8.html#wp1512466
Did it solve the issue?
Varun
Varun Rao
