Intra-Interface-Traffic fails at first try - second try works
Philipp_Flesch
we are running two ASA5550 as fail-over.
Everything works fine. But there is still a little "bug".
same-security-traffic permit intra-interface
is enabled.
Now, let's open an PostgreSQL-Connection from 10.10.1.22 to 10.10.1.8 (same subnet, same interface "IT").
First try (using psql for a connection), I get
11:27:56|106015|10.10.1.22|51019|10.10.1.8|5432|Deny TCP (no connection) from 10.10.1.22/51019 to 10.10.1.8/5432 flags RST  on interface IT
11:27:56|302014|10.10.1.22|51019|10.10.1.8|5432|Teardown TCP connection 290800318 for IT:10.10.1.22/51019 to IT:10.10.1.8/5432 duration 0:00:00 bytes 0 TCP Reset-O
11:27:56|302013|10.10.1.22|51019|10.10.1.8|5432|Built inbound TCP connection 290800318 for IT:10.10.1.22/51019 (10.10.1.22/51019) to IT:10.10.1.8/5432 (10.10.1.8/5432)
11:27:53|302014|10.10.1.22|51019|10.10.1.8|5432|Teardown TCP connection 290800140 for IT:10.10.1.22/51019 to IT:10.10.1.8/5432 duration 0:00:00 bytes 0 TCP Reset-O
11:27:53|302013|10.10.1.22|51019|10.10.1.8|5432|Built inbound TCP connection 290800140 for IT:10.10.1.22/51019 (10.10.1.22/51019) to IT:10.10.1.8/5432 (10.10.1.8/5432)
in the ASA log.
psql now runs into a time out.
Starting the second try, the ASA doesn't report any packets and the connection is established.
Luis Silva Benavides
Phillip,
Based on the syslogs the reset packet is coming from another device "Reset-O". The best way to troubleshoot this issue will be applying captures on the IT interface in order to track the source MAC of the reset and to have a better picture of the traffic flow.
Luis Silva
Luis Silva
